I found a 95 Shasta 240MB on a Ford chassis (Class C). I spent four hours as a rookie checking out everything. Verified everything worked and found two coach seams that let in some water. Chassis looks completely solid and drives like a tiger, (26000 miles) though it appears it has not received much preventive maintenance. Tires have plenty of tread life but are seven years old and have cracks throughout. Everything I read on line states tire life is 8 years MAX. So I guess they need replaced (6 T225/75R16E at $1600). Over the Cab sleeping area: I showed the owner what I think is water damage over the cab. He pulled back some of the wallpaper on the sides and about half way back across the length of the sleeping area. The wood was all wet and saturated. The top layer was rippled 4 -6 inches back from the seam and frayed at the edges. There was also a circular dip spot 7 inches in diameter that did not seem any softer than anywhere else. Upon my comments that this is serious, the 81-year-old hard charging RV owner (155 LBS) commenced to stab it with his pocketknife to show it was still solid. The knife did go in about a 1/8 in but I clearly could not get the knife to go any deeper. I did not try this on the seam for fear it might. He also bounced up and down on the soft cab area. The motivating WW II vet also ordered me to do the same in which I did. We did not fall through the sleeping area and land on the hood. I looked outside of the cab for any noticeable damage but seen nothing other than the two 3-4 inch areas on the side seams where the sealant dry rotted and the water came though. I schedule an appointment for a professional RV tech to give me an estimate.
What do you all think? Should make the buy, let the wood dry, seal up all the seams, and start my maiden voyage? Or, should I consider this real damage, which may require all the moist wood to be replaced at cost around $4500 and pass this one up?
Mike
RVer in waiting
Mike
RVer in waiting
