Raye
Hello,
I’m new to this trailer life and I’m working on winterizing my Starcraft Superlite 212 FB. I got stuck at the water pump while trying to close access to my fresh water tank and use the siphon to add antifreeze.
This is a photo of my water pump. The blue valve top is to my siphon line, the white valve top when following it back goes to a blue hose that goes down into the floor (I think to my fresh water tank?) but then I also have a silver valve that seems to open and close a hose running between the intake side of my pump and the output side of my pump? What is the third silver valve for and how should I set these valves to winterize and keep antifreeze out of my fresh water tank?
Thank you for any advice!
