no sunset tonight
I'm new to RVing and I'm still trying to learn as much as possible. I currently have 2 problems and one question. We just bought a 1991 Itasca Sunflyer class A.
Question-I don't quite understand why certain things will only work with the generator on or only while plugged into AC and not while the motor is running. For example, the TV won't work while the engine is one, only while plugged in or the generator is on. And the AC only while the generator is on but not plugged in. It gets confusing trying to remember what power runs which thing. Why won't it all work off the same power?
First problem, the television & DVD player are plugged into an extention cord then plugged into an outlet. Occassionally, randomly, the TV turns off. It can be turned on immediately without problem BUT the DVD player never loses power. This seems to be a malfunction with the TV but I wanted more opinions before I go buy a new one.
Second problem, while filling the water tanks, they expand with air and bulge out. When I open the vent, it vents both air and water very slowly AND that seems to make it leak water into the under part of the chassis where it runs over to my entrance causing the carpet to get wet. I think we may need a new filling system.
Any help is appreciated!
Thanks from Alaska
Thanks from Alaska
