Wingard Antenna Won't Stay Up
rjf7g
We don't watch much TV, so I didn't know there was an issue until I was doing my spring roof cleaning yesterday. I lubricated the antenna and was going to lift it just to check and see if we could pick up another channel, but the antenna drops back down after about 3/4 turn on the handle. Any ideas? Thanks in advance.
rgrainey
Re: Wingard Antenna Won't Stay Up
Hi Becky,
I have the perfect answer for you. Call my friend Hans Rabong, an engineer at Winegard, at 800-288-8094. I don't think Hans is there on weekends but I think you can get an answer even on Saturday and Sunday. If not call Camping world as they are big dealer for Winegard.
Good luck!
Sounds like a tooth is stripped or out of alignment on the gear system. Should be able to go on top and watch it while someone tries to raise the antenna.
Could be just the set screw in the handle. Mine has come loose.
Grandview Trailer Sa
Becky, The lifting gear is stripped. Easy to install andI have them in stock, just give me a call.Next time we are over, we could deliver one for you.
rjf7g
Kenneth-
Cool - do you have the rubber bushing in stock, too? How much is the lifting gear (and bushing?) (with tax)? I will add it to the check I am already sending you!
Becky,
Linda can tell you tomorrow, but I will be traveling to Kentucky tomorrow delivering a trailer. I don't know if we have the bushing in stock, but we can get it. The gear is not expensive.
