Since replacing the inverter in my Tourmaster last month I have been putting off the job of installing the remote control for the unit.
In this case the entire wire had to be replaced as the old was entirely different with different ends and everything. The old system used 9 pin computer type connectors and then new system was a molded telephone type wiring end.
Today I tackled the job - had to pry loose the silicone rubber sealing the entry into the coach. As luck would have it the entry was up into a corner of the bedroom and then all the cables were tied together and ran under a cabinet, under the bathroom basin cabinet, under the shower and then up the center wall to the middle of the coach.
Had to locate and cut all the nylon ties along the way and some were extremely hard to locate and reach. There is no way I can reinstall the ties so I have to leave them loose.
Managed to hard-tape the new wiring to the old wiring and pull it through the inside ok.
Up and running - monitor and controls work well and now the only thing I have to do is install the new battery cables with the proper sized ones. (had to have the heavy duty cables made as no one carried anything heavier than size 2).
We are getting anxious for next may as that will kick off our ability to start taking a week or two a month and use our motorhome. By the next year then - 2006 we will be retired and intend to head out by the end of October and return sometime around the first part of April each year.
God Bless. Looking forward to seeing a lot of you folks out there and if you see us coming - please feel welcome and stop and visit.
Bill and Judy
Bill and Judy
