maineiac33
At all costs I wanted to avoid having to ask another towing question, but after reading WAY TOO many posts this evening I am now more confused than ever. I currently own a 06 Dodge Durango with :
3.55 Axle Ratio Axle Ratio You Can Tow 5750 lbs
Gross Vehicle Weight Rating (GVWR) = 6700 lbs
Payload = 1604 lbs
Curb Weight = 5096 lbs
Curb Weight Front/Rear = 2744 lbs/2744 lbs
GAWR Front/Rear = 3600 lbs/3900 lbs
Gross Combination Weight Rating (GCWR) = 11000 lbs
I am considering purchasing a Shamrock 21RS travel trailer for my family and its stats are:
Hitch Weight 451 lbs. (205 kg)
Axle Weight 3,032 lbs. (1375 kg)
Unit Dry Weight 3,483 lbs. (1580 kg)
GVWR 4,851 lbs. (2200 kg)
I seem to think that I will be fine towing this trailer, but I suddenly got a little paranoid that I may be way off base. Could someone help a newbee out??? Thanks
Payload = 1604 lbs
