spearson99
Can someone give me some advice on the best way to level? More specifcally, should I unhook once I get my axles close to level with blocks? If I do this, how do you lock the set of tires that are up on blocks?
I have had some concern on uneven ground with the unit "tipping" as i get the corners levelled.
Basically i have some blocks that i will put under one set of tandem wheels to get the trailer level across the "8 foot". I then unhook and use the tongue jack to get things close and use the 4 corner sissor jacks to stabilize things....Is this correct? If yes, how, or what do i do to lock down the tandem wheels up on blocks...the other side i used the wheel stops but up on blocks is another story and they are actually free to turn...thus the tipping possiblity.
Thoughts or comments?
Thanks
Thanks
